Ana içeriğe geç
Alienware M17-R1 CPU Cooler Replacement
Neye ihtiyacın var
  1. Alienware M17-R1 CPU Cooler Replacement, Battery: adım 1, 1 resimden 1.
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 CPU Cooler Replacement: adım 2, 1 resimden 1.
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: adım 3, 1 resimden 1.
    • First begin by placing the laptop on a hard flat surface.
    • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
  4. Alienware M17-R1 CPU Cooler Replacement: adım 4, 1 resimden 1.
    • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
  5. Alienware M17-R1 CPU Cooler Replacement: adım 5, 1 resimden 1.
    • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
    • Screws 1 through 4 are integrated into the cooler and will come all the way out.
  6. Alienware M17-R1 CPU Cooler Replacement: adım 6, 1 resimden 1.
    • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
Sonuç
LXA054
337 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 825
