Giriş
The CPU Cooler is one part of the many different components that combine to make this laptop into a fine tuned machine. Double check your part and make sure it is the CPU cooler and not the GPU cooler.
Neye ihtiyacın var
First begin by placing the laptop on a hard flat surface.
Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
