Ana içeriğe geç
Alienware M17-R1 RAM Replacement
Neye ihtiyacın var
  1. Alienware M17-R1 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: adım 2, 1 resimden 1.
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: adım 4, 2 resimden 1. Alienware M17-R1 RAM Replacement: adım 4, 2 resimden 2.
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: adım 5, 1 resimden 1.
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: adım 6, 2 resimden 1. Alienware M17-R1 RAM Replacement: adım 6, 2 resimden 2.
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: adım 7, 1 resimden 1.
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
Sonuç
LXA054
337 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 806
