Ana içeriğe geç
Alienware M17-R1 Screen Lock Assembly Replacement
Neye ihtiyacın var
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: adım 1, 1 resimden 1.
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware M17-R1 Screen Lock Assembly Replacement: adım 2, 2 resimden 1. Alienware M17-R1 Screen Lock Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware M17-R1 Screen Lock Assembly Replacement: adım 3, 2 resimden 1. Alienware M17-R1 Screen Lock Assembly Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware M17-R1 Screen Lock Assembly Replacement: adım 4, 3 resimden 1. Alienware M17-R1 Screen Lock Assembly Replacement: adım 4, 3 resimden 2. Alienware M17-R1 Screen Lock Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware M17-R1 Screen Lock Assembly Replacement: adım 5, 2 resimden 1. Alienware M17-R1 Screen Lock Assembly Replacement: adım 5, 2 resimden 2.
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
    FixBot'a Sor
    Yorum Ekle
  6. Alienware M17-R1 Screen Lock Assembly Replacement: adım 6, 2 resimden 1. Alienware M17-R1 Screen Lock Assembly Replacement: adım 6, 2 resimden 2.
    • If the spring is defective, slide it off the end of the assembly and replace it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
William Davis
323 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 727
