Ana içeriğe geç
Alienware M17x Display Assembly Replacement
Neye ihtiyacın var
  1. Alienware M17x Display Assembly Replacement, Battery: adım 1, 2 resimden 1. Alienware M17x Display Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware M17x Display Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware M17x Display Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware M17x Display Assembly Replacement: adım 4, 2 resimden 1. Alienware M17x Display Assembly Replacement: adım 4, 2 resimden 2.
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware M17x Display Assembly Replacement, Display Assembly: adım 5, 1 resimden 1.
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
    FixBot'a Sor
    Yorum Ekle
  6. Alienware M17x Display Assembly Replacement: adım 6, 3 resimden 1. Alienware M17x Display Assembly Replacement: adım 6, 3 resimden 2. Alienware M17x Display Assembly Replacement: adım 6, 3 resimden 3.
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
    FixBot'a Sor
    Yorum Ekle
  7. Alienware M17x Display Assembly Replacement: adım 7, 2 resimden 1. Alienware M17x Display Assembly Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to disconnect the screen from the top mount.
    FixBot'a Sor
    Yorum Ekle
  8. Alienware M17x Display Assembly Replacement: adım 8, 1 resimden 1.
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
    FixBot'a Sor
    Yorum Ekle
  9. Alienware M17x Display Assembly Replacement: adım 9, 1 resimden 1.
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 1,010
