Ana içeriğe geç
Alienware M17x Motherboard Replacement
Neye ihtiyacın var
    1. Alienware M17x Motherboard Replacement, Battery: adım 1, 2 resimden 1. Alienware M17x Motherboard Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M17x Motherboard Replacement: adım 2, 1 resimden 1.
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M17x Motherboard Replacement: adım 3, 1 resimden 1.
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M17x Motherboard Replacement: adım 4, 2 resimden 1. Alienware M17x Motherboard Replacement: adım 4, 2 resimden 2.
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware M17x Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
      • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
      • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
      • Twelve 5.5 mm Phillips #0 main frame screws.
      • Six 3.5 mm Phillips #0 fan screws.
      • Four 3.5 mm Phillips #0 internal compartment screws.
      • Eight 3.5 mm Phillips #0 Hard Drive screws.
      • Four 3.5 mm Phillips #0 CD Drive screws.
      • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M17x Motherboard Replacement: adım 6, 3 resimden 1. Alienware M17x Motherboard Replacement: adım 6, 3 resimden 2. Alienware M17x Motherboard Replacement: adım 6, 3 resimden 3.
      • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
      • Use a plastic opening tool to pry the keyboard from the base of the computer.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M17x Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove five 3.5 mm Phillips #0 screws from the motherboard.
      • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
      • Lift the motherboard at an angle and remove it from the computer base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 36
Her zaman: 2,485
