Ana içeriğe geç
Alienware M17x P01E RAM Replacement
Neye ihtiyacın var
  1. Alienware M17x P01E RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E RAM Replacement: adım 2, 2 resimden 1. Alienware M17x P01E RAM Replacement: adım 2, 2 resimden 2.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E RAM Replacement, Compartment Door: adım 3, 1 resimden 1.
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E RAM Replacement: adım 4, 2 resimden 1. Alienware M17x P01E RAM Replacement: adım 4, 2 resimden 2.
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E RAM Replacement, RAM: adım 5, 2 resimden 1. Alienware M17x P01E RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Remove the Phillips #1 screw holding the plate.
    • Use your hand to remove the plate.
    • The screw is held to the plate by a washer and cannot be removed.
  6. Alienware M17x P01E RAM Replacement: adım 6, 2 resimden 1. Alienware M17x P01E RAM Replacement: adım 6, 2 resimden 2.
    • Pull the clips to the side away from each other. The RAM will pop up.
    • Lift forward and gently loosen to pull out of socket.
  7. Alienware M17x P01E RAM Replacement: adım 7, 1 resimden 1.
    • For the second RAM card use the opening tool to gently lift the RAM card forward.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jose
324 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G2, Bruce Fall 2018 CSU Fullerton, Team S2-G2, Bruce Fall 2018 üyesi
CSUF-BRUCE-F18S2G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 704
