Ana içeriğe geç
Alienware M17x RAM Replacement
Neye ihtiyacın var
    1. Alienware M17x RAM Replacement, Battery: adım 1, 2 resimden 1. Alienware M17x RAM Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M17x RAM Replacement: adım 2, 1 resimden 1.
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M17x RAM Replacement: adım 3, 1 resimden 1.
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M17x RAM Replacement: adım 4, 2 resimden 1. Alienware M17x RAM Replacement: adım 4, 2 resimden 2.
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware M17x RAM Replacement, RAM: adım 5, 2 resimden 1. Alienware M17x RAM Replacement, RAM: adım 5, 2 resimden 2.
      • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M17x RAM Replacement: adım 6, 2 resimden 1. Alienware M17x RAM Replacement: adım 6, 2 resimden 2.
      • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
      • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M17x RAM Replacement: adım 7, 1 resimden 1.
      • Remove the bottom RAM card in a similar manner.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 882
