Ana içeriğe geç
Alienware M18x Internal Fan Replacement
Neye ihtiyacın var
  1. Alienware M18x Internal Fan Replacement, Internal Fan: adım 1, 3 resimden 1. Alienware M18x Internal Fan Replacement, Internal Fan: adım 1, 3 resimden 2. Alienware M18x Internal Fan Replacement, Internal Fan: adım 1, 3 resimden 3.
    • Turn the computer over.
    • Slide the battery latch over and lift the battery out.
  2. Alienware M18x Internal Fan Replacement: adım 2, 1 resimden 1.
    • Unscrew the four indicated screws with a J000 screwdriver.
  3. Alienware M18x Internal Fan Replacement: adım 3, 2 resimden 1. Alienware M18x Internal Fan Replacement: adım 3, 2 resimden 2.
    • Use the plastic pryer tool to lift the bottom cover off.
  4. Alienware M18x Internal Fan Replacement: adım 4, 2 resimden 1. Alienware M18x Internal Fan Replacement: adım 4, 2 resimden 2.
    • With the back cover removed, locate the desired fan to replace.
  5. Alienware M18x Internal Fan Replacement: adım 5, 3 resimden 1. Alienware M18x Internal Fan Replacement: adım 5, 3 resimden 2. Alienware M18x Internal Fan Replacement: adım 5, 3 resimden 3.
    • Use a J000 screwdriver to loosen the screws that secure the fan(s).
    • There are three internal fans within the laptop. Locate the correct screws to loosen for the desired fan to replace based on the provided corresponding images.
  6. Alienware M18x Internal Fan Replacement: adım 6, 3 resimden 1. Alienware M18x Internal Fan Replacement: adım 6, 3 resimden 2. Alienware M18x Internal Fan Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
  7. Alienware M18x Internal Fan Replacement: adım 7, 2 resimden 1. Alienware M18x Internal Fan Replacement: adım 7, 2 resimden 2.
    • The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
Sonuç
Jonathan Panella
470 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G1, Banghart Winter 2018 Cal Poly, Team S21-G1, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S21G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 633
