Ana içeriğe geç
Alienware P18G M14X R1 Battery Replacement
Neye ihtiyacın var
    1. Alienware P18G M14X R1 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
      • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware P18G M14X R1 Battery Replacement: adım 2, 1 resimden 1.
      • Slide back cover forward using your thumbs.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware P18G M14X R1 Battery Replacement: adım 3, 1 resimden 1.
      • Lift up the cover and set aside exposing the internals of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware P18G M14X R1 Battery Replacement, Battery: adım 4, 1 resimden 1.
      • Make sure the laptop is turned off before starting.
      • Using PH1 screwdriver loosen the two screws on the right of the battery.
      • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware P18G M14X R1 Battery Replacement: adım 5, 2 resimden 1. Alienware P18G M14X R1 Battery Replacement: adım 5, 2 resimden 2.
      • Pull battery up using the tab provided.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware P18G M14X R1 Battery Replacement: adım 6, 1 resimden 1.
      • Disconnect the clip connecting the battery to the computer.
      • Set battery aside.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andonaq Grozdani
892 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 UMass Dartmouth, Team S2-G2, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G2
3 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 2,545
