Ana içeriğe geç
Alienware P18G M14X R1 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: adım 4, 1 resimden 1.
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: adım 5, 2 resimden 1. Alienware P18G M14X R1 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: adım 7, 1 resimden 1.
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: adım 9, 1 resimden 1.
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: adım 10, 1 resimden 1.
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: adım 11, 1 resimden 1.
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: adım 12, 1 resimden 1.
    • Pull the clip away from the hard drive to remove it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Andonaq Grozdani
892 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 UMass Dartmouth, Team S2-G2, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 3,283
