Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Lift up the cover and set aside exposing the internals of the computer.
Using PH1 screwdriver loosen the two screws on the right of the battery.
Disconnect the clip connecting the battery to the computer.
Set battery aside.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Using the plastic opening tool unclip the white connector holding down the orange cable.
Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
