Ana içeriğe geç
Alienware P18G M14X R1 RAM Replacement
Neye ihtiyacın var
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware P18G M14X R1 RAM Replacement: adım 2, 1 resimden 1.
    • Slide back cover forward using your thumbs.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware P18G M14X R1 RAM Replacement: adım 3, 1 resimden 1.
    • Lift up the cover and set aside exposing the internals of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware P18G M14X R1 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Unscrew the two 6.35 mm using the PH1 screw driver.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware P18G M14X R1 RAM Replacement: adım 5, 2 resimden 1. Alienware P18G M14X R1 RAM Replacement: adım 5, 2 resimden 2.
    • Lift the plate and remove it to uncover the RAM sticks.
    FixBot'a Sor
    Yorum Ekle
  6. Alienware P18G M14X R1 RAM Replacement: adım 6, 1 resimden 1.
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
    FixBot'a Sor
    Yorum Ekle
  7. Alienware P18G M14X R1 RAM Replacement: adım 7, 1 resimden 1.
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
    FixBot'a Sor
    Yorum Ekle
  8. Alienware P18G M14X R1 RAM Replacement: adım 8, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  9. Alienware P18G M14X R1 RAM Replacement: adım 9, 1 resimden 1.
    • Pull the second ram stick out of its housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Andonaq Grozdani
892 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 UMass Dartmouth, Team S2-G2, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,385
