Ana içeriğe geç
Alienware X51 Disc Drive Replacement
Neye ihtiyacın var
  1. Alienware X51 Disc Drive Replacement, Front Panel: adım 1, 1 resimden 1.
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Disc Drive Replacement: adım 2, 1 resimden 1.
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Disc Drive Replacement, Disc Drive: adım 3, 2 resimden 1. Alienware X51 Disc Drive Replacement, Disc Drive: adım 3, 2 resimden 2.
    • Disconnect the optical-drive data and power cable.
  4. Alienware X51 Disc Drive Replacement: adım 4, 1 resimden 1.
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 121
Her zaman: 344
