Ana içeriğe geç
Alienware X51 Fan Replacement
Neye ihtiyacın var
  1. Alienware X51 Fan Replacement, Front Panel: adım 1, 1 resimden 1.
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware X51 Fan Replacement: adım 2, 1 resimden 1.
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware X51 Fan Replacement, Fan: adım 3, 2 resimden 1. Alienware X51 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware X51 Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the Molex KK connector from the fan.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware X51 Fan Replacement: adım 5, 3 resimden 1. Alienware X51 Fan Replacement: adım 5, 3 resimden 2. Alienware X51 Fan Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 809
