Ana içeriğe geç
Alienware X51 Heatsink Replacement
Neye ihtiyacın var
  1. Alienware X51 Heatsink Replacement, Front Panel: adım 1, 1 resimden 1.
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Heatsink Replacement: adım 2, 1 resimden 1.
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Heatsink Replacement, Fan: adım 3, 2 resimden 1. Alienware X51 Heatsink Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Heatsink Replacement: adım 4, 1 resimden 1.
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Heatsink Replacement: adım 5, 3 resimden 1. Alienware X51 Heatsink Replacement: adım 5, 3 resimden 2. Alienware X51 Heatsink Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Heatsink Replacement, Heatsink: adım 6, 3 resimden 1. Alienware X51 Heatsink Replacement, Heatsink: adım 6, 3 resimden 2. Alienware X51 Heatsink Replacement, Heatsink: adım 6, 3 resimden 3.
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
Sonuç
alondra
123 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 143
