Ana içeriğe geç
Alienware X51 Motherboard Replacement
Neye ihtiyacın var
  1. Alienware X51 Motherboard Replacement, Front Panel: adım 1, 1 resimden 1.
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Motherboard Replacement: adım 2, 1 resimden 1.
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Motherboard Replacement, Fan: adım 3, 2 resimden 1. Alienware X51 Motherboard Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Motherboard Replacement: adım 5, 3 resimden 1. Alienware X51 Motherboard Replacement: adım 5, 3 resimden 2. Alienware X51 Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Motherboard Replacement, Disc Drive: adım 6, 2 resimden 1. Alienware X51 Motherboard Replacement, Disc Drive: adım 6, 2 resimden 2.
    • Disconnect the optical-drive data and power cable.
  7. Alienware X51 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
  8. Alienware X51 Motherboard Replacement, RAM: adım 8, 3 resimden 1. Alienware X51 Motherboard Replacement, RAM: adım 8, 3 resimden 2. Alienware X51 Motherboard Replacement, RAM: adım 8, 3 resimden 3.
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
  9. Alienware X51 Motherboard Replacement, Heatsink: adım 9, 3 resimden 1. Alienware X51 Motherboard Replacement, Heatsink: adım 9, 3 resimden 2. Alienware X51 Motherboard Replacement, Heatsink: adım 9, 3 resimden 3.
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
  10. Alienware X51 Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Alienware X51 Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • Remove the single 1.0 mm screw with a Phillips #1 screwdriver.
    • Firmly remove the internal PC system by lifting it out of the PC.
  11. Alienware X51 Motherboard Replacement: adım 11, 2 resimden 1. Alienware X51 Motherboard Replacement: adım 11, 2 resimden 2.
    • Loosen the four 1.0 mm screws holding down the motherboard using a Phillips #1 screwdriver.
  12. Alienware X51 Motherboard Replacement: adım 12, 2 resimden 1. Alienware X51 Motherboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the two SATA plugs going into the motherboard processor.
  13. Alienware X51 Motherboard Replacement: adım 13, 1 resimden 1.
    • Disconnect the rectangular power supply plug from the motherboard into the other circuit board.
  14. Alienware X51 Motherboard Replacement: adım 14, 1 resimden 1.
    • Disconnect the bundled cable connector going into the motherboard.
  15. Alienware X51 Motherboard Replacement: adım 15, 1 resimden 1.
    • Disconnect the white bundled cable connector from the motherboard.
  16. Alienware X51 Motherboard Replacement: adım 16, 1 resimden 1.
    • Disconnect the rectangular yellow bundled cable connector plug going into the motherboard.
  17. Alienware X51 Motherboard Replacement: adım 17, 1 resimden 1.
    • Disconnect the power supply.
  18. Alienware X51 Motherboard Replacement: adım 18, 1 resimden 1.
    • Disconnect the rectangular white bundled cable connector going into the motherboard.
  19. Alienware X51 Motherboard Replacement: adım 19, 2 resimden 1. Alienware X51 Motherboard Replacement: adım 19, 2 resimden 2.
    • Gently slide and lift out the motherboard from the PC.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Braedon
402 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 393
