Ana içeriğe geç
Alienware X51 R2/R3 CPU Replacement
Neye ihtiyacın var
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): adım 1, 1 resimden 1.
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware X51 R2/R3 CPU Replacement: adım 2, 1 resimden 1.
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware X51 R2/R3 CPU Replacement: adım 3, 1 resimden 1.
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware X51 R2/R3 CPU Replacement: adım 4, 1 resimden 1.
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware X51 R2/R3 CPU Replacement: adım 5, 1 resimden 1.
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
2 farklı kişi bu kılavuzu tamamladı.
rcschwartz709
220 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 55
Her zaman: 3,243
