Ana içeriğe geç
Alienware X51 RAM Replacement
Neye ihtiyacın var
    1. Alienware X51 RAM Replacement, Front Panel: adım 1, 1 resimden 1.
      • Place the PC so the name "Alienware" is on top and facing you.
      • Slide the front panel towards you and lift up.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware X51 RAM Replacement: adım 2, 1 resimden 1.
      • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
      • Remove the front panel from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware X51 RAM Replacement, Fan: adım 3, 2 resimden 1. Alienware X51 RAM Replacement, Fan: adım 3, 2 resimden 2.
      • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
      • Remove the protector holding the fan in.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware X51 RAM Replacement: adım 4, 1 resimden 1.
      • Disconnect the Molex KK connector from the fan.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware X51 RAM Replacement: adım 5, 3 resimden 1. Alienware X51 RAM Replacement: adım 5, 3 resimden 2. Alienware X51 RAM Replacement: adım 5, 3 resimden 3.
      • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
      • Gently pull back the clips and remove the fan by pulling it out.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware X51 RAM Replacement, Disc Drive: adım 6, 2 resimden 1. Alienware X51 RAM Replacement, Disc Drive: adım 6, 2 resimden 2.
      • Disconnect the optical-drive data and power cable.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware X51 RAM Replacement: adım 7, 1 resimden 1.
      • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
      • Remove the disc drive from the PC.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware X51 RAM Replacement, RAM: adım 8, 3 resimden 1. Alienware X51 RAM Replacement, RAM: adım 8, 3 resimden 2. Alienware X51 RAM Replacement, RAM: adım 8, 3 resimden 3.
      • Pull apart the clips that hold the RAM sticks in place.
      • Remove the RAM sticks.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 568
