Ana içeriğe geç
Alienware m15 R6 Display Replacement
Neye ihtiyacın var
  1. Alienware m15 R6 Display Replacement, Base Cover: adım 1, 1 resimden 1.
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Display Replacement: adım 2, 1 resimden 1.
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Display Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Display Replacement, Rear-I/O cover: adım 4, 1 resimden 1.
    • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Disconnect the Tron light cable from the system board.
    • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
    • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
  5. Alienware m15 R6 Display Replacement, Display: adım 5, 1 resimden 1.
    • Open the latch and disconnect the display cable from the system board.
    • Disconnect the Alienhead LED cable from the system board.
    • Disconnect the RGB-IR camera cable from the USB board.
    • Lift the system board Mylar and peel the tapes that secure the RGB-IR camera cable to the system board.
    • Lift the RGB-IR camera cable off the system board.
    • Turn the computer over and place the computer on a clean and flat surface.
    • Remove the display cable from the routing guides on the palm-rest and keyboard assembly.
    • Remove the RGB-IR camera cable from the routing guides on the palm-rest and keyboard assembly.
  6. Alienware m15 R6 Display Replacement: adım 6, 1 resimden 1.
    • Remove the six screws (M2.5x5) that secure the display hinges to the palm-rest and keyboard assembly.
    • Lift the display assembly off the palm-rest and keyboard assembly.
  7. Alienware m15 R6 Display Replacement: adım 7, 1 resimden 1.
    • After performing all the above steps, you are left with the display assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrzej
1.672 İtibar
18 adet Kılavuz yazıldı
1Rehber Yorum
How do you replace the LCD ribbon cable? It seems to be glued to the screen. I just need to replace that cable because it broke when I had to disconnect it to replace the charging port. :(
Melissa Ceyrolles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 927
