Ana içeriğe geç
Alienware m15 R6 Power-adapter port Replacement
Neye ihtiyacın var
  1. Alienware m15 R6 Power-adapter port Replacement, Base Cover: adım 1, 1 resimden 1.
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Power-adapter port Replacement: adım 2, 1 resimden 1.
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Power-adapter port Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Power-adapter port Replacement, Rear-I/O cover: adım 4, 1 resimden 1.
    • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Disconnect the Tron light cable from the system board.
    • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
    • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
  5. Alienware m15 R6 Power-adapter port Replacement, Power-adapter port: adım 5, 1 resimden 1.
    • Open the latch and disconnect the display cable from the system board.
    • Disconnect the Alienhead LED cable from the system board.
    • Peel the display cable from the system board and remove the display cable from the slot on the system board.
    • Lift the system board Mylar next to the left fan to access the power-adapter port.
    • Remove the two screws (M2x4) on the power-adapter port-bracket that secures the power-adapter port bracket to the systemboard.
    • Lift the power-adapter port-bracket off the system board.
    • Disconnect the power-adapter port-cable from the system board.
    • Peel and lift the power-adapter port, along with its cable, off the system board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrzej
1.672 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 524
