Giriş
The Alldaymall A88X has a 3000mAh battery that is glued to the back of the LCD screen and soldered to the motherboard. This guide will walk you through the process of removing the existing battery and installing a new one.
Neye ihtiyacın var
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
4 farklı kişi bu kılavuzu tamamladı.
