Ana içeriğe geç
AlphaSmart Pro Front Panel Replacement
Neye ihtiyacın var
    1. AlphaSmart Pro Front Panel Replacement, Separating Panels: adım 1, 3 resimden 1. AlphaSmart Pro Front Panel Replacement, Separating Panels: adım 1, 3 resimden 2. AlphaSmart Pro Front Panel Replacement, Separating Panels: adım 1, 3 resimden 3.
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: adım 2, 2 resimden 1. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: adım 2, 2 resimden 2.
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • You are now able to separate the front panel from the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: adım 3, 3 resimden 1. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: adım 3, 3 resimden 2. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: adım 3, 3 resimden 3.
      • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
      • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nathan Smith
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S1G1
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 36
Her zaman: 613
