Giriş
The rear panel may need to be replaced if it is cracked or damaged.
Neye ihtiyacın var
Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
Carefully separate the front panel from the back panel.
To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
Gently pull up on the connector to completely remove the connector from the socket.
Remove front panel from the motherboard.
Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
Gently lift the keyboard from the rear panel.
To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
Pull the ribbon cable to remove it from the connector.
Repeat the exact steps above for the other ribbon cable.
Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
Carefully lift the motherboard away from the rear panel.
