Ana içeriğe geç
Alpine MRV-M500 Circuit Board Replacement
Neye ihtiyacın var
  1. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 1. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 2. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 3.
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
  2. Alpine MRV-M500 Circuit Board Replacement: adım 2, 2 resimden 1. Alpine MRV-M500 Circuit Board Replacement: adım 2, 2 resimden 2.
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  3. Alpine MRV-M500 Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board from the case.
Sonuç
To reassemble your device, follow these instructions in reverse order using the replacement circuit board.
4 farklı kişi bu kılavuzu tamamladı.
Eric Gaulke
623 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 2,037
