Ana içeriğe geç
Altec Lansing BoomJacket 2 Disassembly
Neye ihtiyacın var
  1. Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: adım 1, 2 resimden 1. Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: adım 1, 2 resimden 2.
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Disassembly: adım 2, 2 resimden 1. Altec Lansing BoomJacket 2 Disassembly: adım 2, 2 resimden 2.
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Disassembly: adım 3, 1 resimden 1.
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Disassembly: adım 4, 2 resimden 1. Altec Lansing BoomJacket 2 Disassembly: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Disassembly: adım 5, 1 resimden 1.
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Disassembly: adım 6, 1 resimden 1.
    • Gently pull apart the front panel from the base of the speaker.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zach Braaten
516 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,508
