Ana içeriğe geç
Altec Lansing BoomJacket 2 Motherboard Replacement
Neye ihtiyacın var
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: adım 1, 2 resimden 1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: adım 1, 2 resimden 2.
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
    FixBot'a Sor
    Yorum Ekle
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 2, 2 resimden 1. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
    FixBot'a Sor
    Yorum Ekle
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 3, 1 resimden 1.
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
    FixBot'a Sor
    Yorum Ekle
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 4, 2 resimden 1. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
    FixBot'a Sor
    Yorum Ekle
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
    FixBot'a Sor
    Yorum Ekle
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently pull apart the front panel from the base of the speaker.
    FixBot'a Sor
    Yorum Ekle
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: adım 7, 1 resimden 1.
    • The battery will be in the middle of the speaker when the case is open.
    FixBot'a Sor
    Yorum Ekle
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
    FixBot'a Sor
    Yorum Ekle
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
    FixBot'a Sor
    Yorum Ekle
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 10, 1 resimden 1.
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
    FixBot'a Sor
    Yorum Ekle
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: adım 11, 1 resimden 1.
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zach Braaten
537 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G4
4 Üyeler
1Rehber Yorum
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 1,211
