Ana içeriğe geç
Altec Lansing BoomJacket Battery Replacement
Neye ihtiyacın var
    1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: adım 1, 1 resimden 1.
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. Altec Lansing BoomJacket Battery  Replacement: adım 2, 1 resimden 1.
      • Remove the outer black rubber housing of the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. Altec Lansing BoomJacket Battery  Replacement: adım 3, 1 resimden 1.
      • Remove the inner blue rubber housing from the speaker.
      FixBot'a Sor
      Yorum Ekle
    4. Altec Lansing BoomJacket Battery  Replacement: adım 4, 1 resimden 1.
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      FixBot'a Sor
      Yorum Ekle
    5. Altec Lansing BoomJacket Battery  Replacement: adım 5, 2 resimden 1. Altec Lansing BoomJacket Battery  Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      FixBot'a Sor
      Yorum Ekle
    6. Altec Lansing BoomJacket Battery  Replacement: adım 6, 1 resimden 1.
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      FixBot'a Sor
      Yorum Ekle
    7. Altec Lansing BoomJacket Battery  Replacement: adım 7, 1 resimden 1.
      • Pull the case apart and you will be able to see all the components inside the speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Altec Lansing BoomJacket Battery  Replacement, Battery: adım 8, 1 resimden 1.
      • The battery will be sitting right behind the speakers when the case is open.
      FixBot'a Sor
      Yorum Ekle
    2. Altec Lansing BoomJacket Battery  Replacement: adım 9, 1 resimden 1.
      • Unplug and disconnect the battery from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
Where can you buy a replacement battery?
Darrell riley - Yanıt Paylaş
Where can you buy the battery please?
Juan Roa - Yanıt Paylaş
Where can I find ghe batteries? What type of battery ?
Violet Roach - Yanıt Paylaş
where ca i buy a replacement battery
Shelley Franck - Yanıt Paylaş
This tutorial is incomplete.
Ivan Rodriguez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 68
Her zaman: 15,976
