Ana içeriğe geç
Altec Lansing BoomJacket Power Button Replacement
Neye ihtiyacın var
    1. Altec Lansing BoomJacket Power Button Replacement, Case Removal: adım 1, 1 resimden 1.
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. Altec Lansing BoomJacket Power Button Replacement: adım 2, 1 resimden 1.
      • Remove the outer black rubber housing of the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. Altec Lansing BoomJacket Power Button Replacement: adım 3, 1 resimden 1.
      • Remove the inner blue rubber housing from the speaker.
      FixBot'a Sor
      Yorum Ekle
    4. Altec Lansing BoomJacket Power Button Replacement: adım 4, 1 resimden 1.
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      FixBot'a Sor
      Yorum Ekle
    5. Altec Lansing BoomJacket Power Button Replacement: adım 5, 2 resimden 1. Altec Lansing BoomJacket Power Button Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      FixBot'a Sor
      Yorum Ekle
    6. Altec Lansing BoomJacket Power Button Replacement: adım 6, 1 resimden 1.
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      FixBot'a Sor
      Yorum Ekle
    7. Altec Lansing BoomJacket Power Button Replacement: adım 7, 1 resimden 1.
      • Pull the case apart and you will be able to see all the components inside the speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Altec Lansing BoomJacket Power Button Replacement, Power Button: adım 8, 1 resimden 1.
      • The battery will be sitting right behind the speakers when the case is open.
      FixBot'a Sor
      Yorum Ekle
    2. Altec Lansing BoomJacket Power Button Replacement: adım 9, 2 resimden 1. Altec Lansing BoomJacket Power Button Replacement: adım 9, 2 resimden 2.
      • Unplug and disconnect the battery from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Altec Lansing BoomJacket Power Button Replacement: adım 10, 1 resimden 1.
      • Using a size PH1 screwdriver, remove the two screws.
      FixBot'a Sor
      Yorum Ekle
    4. Altec Lansing BoomJacket Power Button Replacement: adım 11, 2 resimden 1. Altec Lansing BoomJacket Power Button Replacement: adım 11, 2 resimden 2.
      • You will now see the motherboard for the power button.
      • Remove the 2 screws holding the motherboard into place.
      FixBot'a Sor
      Yorum Ekle
    5. Altec Lansing BoomJacket Power Button Replacement: adım 12, 1 resimden 1.
      • Pick up the motherboard and take it out of the slot.
      FixBot'a Sor
      Yorum Ekle
    6. Altec Lansing BoomJacket Power Button Replacement: adım 13, 1 resimden 1.
      • Disconnect the power button motherboard from the speaker motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Current speaker won’t turn on even though charging light looks all good so came across these instructions.
Thinking it’s the power button on my speaker that’s the issue.
Assuming these instructions are assuming you are replacing the power button motherboard? Where could I source one?
Cat Moure - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 21,362
