Giriş
If the battery in your Altec Lansing Mini Lifejacket 2 isn't holding a charge or is showing signs of failure, use this guide to replace it.
Neye ihtiyacın var
Use the spudger to remove the eight black pins from the front and back of the wire screens.
8 farklı kişi bu kılavuzu tamamladı.
13Kılavuz Yorumları
Search for MCR18650 battery. They are available.
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
Sounds like you need to find another source instead of aliexpress or ebay. Digikey has them with the correct 2 wire connection. It's just a standard 18650 battery with the wires spot welded to the positive and negative terminals. Anything with a 3rd wire is likely meant as a charge sensing wire for a batter that has on board circuitry.
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
