Ana içeriğe geç
Altec Lansing Mini Lifejacket 2 Motherboard Replacement
Neye ihtiyacın var
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    FixBot'a Sor
    Yorum Ekle
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 2, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 2, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 2, 3 resimden 3.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    FixBot'a Sor
    Yorum Ekle
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 3, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove both black and orange layers from the speaker body.
    FixBot'a Sor
    Yorum Ekle
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 4, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 4, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 5, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    FixBot'a Sor
    Yorum Ekle
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 6, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    FixBot'a Sor
    Yorum Ekle
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull the case apart to access the interior components.
    FixBot'a Sor
    Yorum Ekle
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 9, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 9, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 9, 3 resimden 3.
    • To remove the back panel, gently pull out its wire harness.
    FixBot'a Sor
    Yorum Ekle
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: adım 10, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: adım 10, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: adım 10, 3 resimden 3.
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Unplug the remaining four wire harnesses attached to the circuit board
    FixBot'a Sor
    Yorum Ekle
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 12, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
    FixBot'a Sor
    Yorum Ekle
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 13, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 13, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephen Albrecht
1.053 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Spring 2018 USF Tampa, Team S3-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G2
4 Üyeler
6Kılavuz Yorumları
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Yanıt Paylaş
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Yanıt Paylaş
need back panel replacement
rahul pande - Yanıt Paylaş
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Yanıt Paylaş
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 6,357
