Ana içeriğe geç
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Neye ihtiyacın var
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    FixBot'a Sor
    Yorum Ekle
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 3.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    FixBot'a Sor
    Yorum Ekle
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 3, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove both black and orange layers from the speaker body.
    FixBot'a Sor
    Yorum Ekle
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 5, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 5, 2 resimden 2.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    FixBot'a Sor
    Yorum Ekle
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 6, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    FixBot'a Sor
    Yorum Ekle
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 8, 1 resimden 1.
    • Pull the case apart to access the interior components.
    FixBot'a Sor
    Yorum Ekle
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 3.
    • To remove the back panel, gently pull out its wire harness.
    FixBot'a Sor
    Yorum Ekle
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: adım 10, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: adım 10, 2 resimden 2.
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
    FixBot'a Sor
    Yorum Ekle
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 3.
    • To remove the speaker, gently pull out the its wire harness.
    FixBot'a Sor
    Yorum Ekle
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 12, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 12, 2 resimden 2.
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Albrecht
1.053 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Spring 2018 USF Tampa, Team S3-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G2
4 Üyeler
3Kılavuz Yorumları
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Yanıt Paylaş
Where can I get this speaker parts?
T Rex movies - Yanıt Paylaş
Where can I get a complete power circuit board from for a Imw575 as mine is completely broken thank you
Paul Williams - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 4,979
