Ana içeriğe geç
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Neye ihtiyacın var
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 2, 3 resimden 3.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 3, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 5, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 5, 2 resimden 2.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 6, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 6, 2 resimden 2.
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 8, 1 resimden 1.
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 9, 3 resimden 3.
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: adım 10, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: adım 10, 2 resimden 2.
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 11, 3 resimden 3.
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 12, 2 resimden 1. Altec Lansing Mini Lifejacket 2 Speaker Replacement: adım 12, 2 resimden 2.
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Albrecht
1.008 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Spring 2018 USF Tampa, Team S3-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G2
4 Üyeler
2 Yorum
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Yanıt
Where can I get this speaker parts?
T Rex movies - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 4,016
