Ana içeriğe geç
Altec Lansing OVO Bluetooth Speaker Disassembly
Neye ihtiyacın var
  1. Altec Lansing OVO Bluetooth Speaker Disassembly, Altec Lansing OVO Bluetooth Speaker Disassembly: adım 1, 1 resimden 1.
    • This is the unit that we are going to disassemble.
  2. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 2, 1 resimden 1.
    • Screws approximate location behind the front cover.
  3. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 3, 1 resimden 1.
    • Use a pick to gently pull the cover. There are no fragile parts. The cover is made of metal and covered with a type of mesh.
  4. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 4, 3 resimden 1. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 4, 3 resimden 2. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 4, 3 resimden 3.
    • Once the front cover is removed gently lift the thin protection layer in order to find the holes where the screws are located. In order to find the two middle screws you will have to make two small incisions as shown in the picture.
  5. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 5, 2 resimden 1. Altec Lansing OVO Bluetooth Speaker Disassembly: adım 5, 2 resimden 2.
    • After you remove the 13 screws, put your finger in the woofer hole on the back of the speaker. Pull gently outwards to make sure you don't break the flat cable that connects the back to the main board. And that's it! Now you have full access to all the inner parts of your speaker.
Sonuç
Bu çevirmenlere özel teşekkürler:
pt en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Nuno
181 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
What is the spec on the battery in this unit (Altec Lansing OVO AL-BT42S)?
Hugo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 1,160
