Ana içeriğe geç
Altec Lansing VersA Smart Bluebooth Board Replacement
Neye ihtiyacın var
  1. Altec Lansing VersA Smart Bluebooth Board Replacement, External Panels: adım 1, 1 resimden 1.
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 2, 2 resimden 1. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 2, 2 resimden 2.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 3, 2 resimden 1. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 3, 2 resimden 2.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 4, 1 resimden 1.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Bluebooth Board Replacement, Bluebooth Board: adım 5, 1 resimden 1.
    • Detach the wiring piece, located in the upper right corner of the motherboard.
  6. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 6, 2 resimden 1. Altec Lansing VersA Smart Bluebooth Board Replacement: adım 6, 2 resimden 2.
    • Remove the daughterboard piece from its designated slot, located to the right of the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachael Hopp
550 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 703
