Giriş
If you are having an issue with your device not charging, access and replace the Micro USB charging port using this guide.
Neye ihtiyacın var
Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
Use a lever motion, push the tool down, lifting the speaker face.
Use fingers to grip and remove speaker face.
Repeat on reverse side to remove the second speaker face.
Remove the plactic piece containing the Micro USB port from its designated slot, found below the speakers.
Bir başkası bu kılavuzu tamamladı.
