Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
In this guide, you will pry off the control panel to unscrew and desolder the circuit boards. If you are not comfortable with soldering, you can use this guide.
Neye ihtiyacın var
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
