Giriş
The woofer is the part of the speaker that outputs lower frequency sounds. Replacement of the woofer requires removal of the batteries, the volume and power buttons, and motherboard. Soldering skills are required; take a look at this soldering guide for extra help.
Parçalar
Hiçbir parça belirtilmedi.
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Bir başkası bu kılavuzu tamamladı.
