Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Instead of a putty knife a dozen or more 1-1/2" pins are required.
With the computer upside down identify the apertures where the catches are located along either side and also at the front.
Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
Lift the case off from the back first.
Remove the pins from the main assembly.
16 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
