Ana içeriğe geç
Aluratek ADMPF310F Motherboard Replacement
Neye ihtiyacın var
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Aluratek ADMPF310F Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: adım 3, 2 resimden 1. Aluratek ADMPF310F Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: adım 6, 2 resimden 1. Aluratek ADMPF310F Motherboard Replacement: adım 6, 2 resimden 2.
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: adım 7, 3 resimden 1. Aluratek ADMPF310F Motherboard Replacement: adım 7, 3 resimden 2. Aluratek ADMPF310F Motherboard Replacement: adım 7, 3 resimden 3.
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
Sonuç
Pascal Alexis
427 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 595
