Ana içeriğe geç
Aluratek ADMPF310F Screen Replacement
Neye ihtiyacın var
  1. Aluratek ADMPF310F Screen Replacement, Screen: adım 1, 3 resimden 1. Aluratek ADMPF310F Screen Replacement, Screen: adım 1, 3 resimden 2. Aluratek ADMPF310F Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Screen Replacement: adım 2, 1 resimden 1.
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Screen Replacement: adım 3, 2 resimden 1. Aluratek ADMPF310F Screen Replacement: adım 3, 2 resimden 2.
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
Sonuç
Chris Belair
333 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 587
