Ana içeriğe geç
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Amazon Astro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Amazon Astro Chip ID, Screen Board Side 1: adım 1, 2 resimden 1. Amazon Astro Chip ID, Screen Board Side 1: adım 1, 2 resimden 2.
    • Chip ID, part 1:
    • MediaTek MT8512BAAV applications processor w/ AZ1 neural edge
    • Samsung K4F8E164HA-MGCL 1 GB LPDDR4 SDRAM memory
    • Samsung KLM4G1FETE-B041 4 GB eMMC NAND flash memory
    • Qualcomm SDA660-201-AA octa-core applications processor
    • SK hynix H9HCNNNCPMMLHR-NME 4 GB LPDDR4X SDRAM memory
    • Kioxia THGBMJG7C1LBAIL 16 GB eMMC NAND flash memory
    • Analog Devices MAX9296A dual GMSL2 deserializer
    FixBot'a Sor
  2. Amazon Astro Chip ID: adım 2, 1 resimden 1.
    • Chip ID, part 2:
    • MediaTek MT6398AN power management
    • Qualcomm PM660-002 power management
    • Qualcomm PM660L-004-01 power management
    • Qualcomm PM3003A power management
    • Monolithic Power Systems MP8756 6 A synchronous step-down converter
    • Richtek RT5797ALGQW 3 A synchronous step-down converter
    • Texas Instruments DC-DC converter (likely)
    FixBot'a Sor
  3. Amazon Astro Chip ID: adım 3, 1 resimden 1.
    • Chip ID, part 3:
    • Silergy SY6287C power distribution switch
    • Texas Instruments INA219A 12-bit current/voltage/power monitor
    • Nexperia 74HC4051 8-ch analog multiplexer/demultiplexer
    • Nexperia 74AUP1G02 single 2-input NOR gate
    • Nexperia 74LVC1G08 single 2-input AND gate
    • onsemi ESD8704MUTAG 4-ch. ESD protection diode array
    FixBot'a Sor
  4. Amazon Astro Chip ID: adım 4, 1 resimden 1.
    • Chip ID, part 4 - connectivity:
    • MediaTek MT7668ASN dual band 2x2 MU-MIMO WiFi 802.11ac & Bluetooth 5.0
    FixBot'a Sor
  5. Amazon Astro Chip ID, Neck Board Side 1: adım 5, 2 resimden 1. Amazon Astro Chip ID, Neck Board Side 1: adım 5, 2 resimden 2.
    • Chip ID, part 1:
    • Intel vision processor (likely)
    • Knowles MEMS Microphone
    • Texas Instruments TPS24750 12 A eFuse w/ current monitor
    • Monolithic Power Systems MP2151GTF 1 A / adj. synchronous step-down converter
    • Renesas mixed signal array
    FixBot'a Sor
  6. Amazon Astro Chip ID: adım 6, 1 resimden 1.
    • Chip ID, part 2:
    • Texas Instruments LP5907UVE-1.8 250 mA / 1.8 V LDO regulator
    • Texas Instruments TPS2553 adjustable USB power distribution switch
    • Texas Instruments TCA9406 2-bit bidirectional voltage-level translator
    • Texas Instruments LMV331 single low voltage comparator
    • NXP Semiconductor NVT2008 8-bit bidirectional voltage level translator
    • Texas Instruments SN74LVC1G66 single SPST analog switch
    • onsemi NC7SZ11 single 3-input AND gate
    FixBot'a Sor
  7. Amazon Astro Chip ID: adım 7, 1 resimden 1.
    • Chip ID, part 3:
    FixBot'a Sor
  8. Amazon Astro Chip ID: adım 8, 1 resimden 1.
    • Chip ID, part 4 - sensors:
    • Texas Instruments TMP103G temperature sensor
    FixBot'a Sor
  9. Amazon Astro Chip ID, Sensor Board Side 1: adım 9, 2 resimden 1. Amazon Astro Chip ID, Sensor Board Side 1: adım 9, 2 resimden 2.
    • Chip ID, part 1:
    • Qualcomm QCS605-001-AC 64-bit octa-core applications processor
    • SK hynix H9HCNNNBKMMLHR-NME 2 GB LPDDR4X SDRAM memory
    • Samsung KLMAG1JETD-B041 16 GB eMMC NAND flash memory
    • STMicroelectronics STM32G031J6 32-bit ARM Cortex-M0+ microcontroller
    • Qualcomm PM670-001 power management
    • Qualcomm PM670L-000-01 power management
    • Texas Instruments TLV320DAC3203 stereo audio CODEC
    FixBot'a Sor
  10. Amazon Astro Chip ID: adım 10, 1 resimden 1.
    • Chip ID, part 2:
    • Texas Instruments TPA3118D2 stereo 30 W class-D audio amplifier
    • Silergy DC-DC converter (likely)
    • Vishay SiP32419 load switch
    • Silergy load switch (likely)
    • Texas Instruments LP5912-3.3 500 mA / 3.3 V LDO regulator
    FixBot'a Sor
  11. Amazon Astro Chip ID: adım 11, 1 resimden 1.
    • Chip ID, part 3:
    • Texas Instruments TXS0102 2-bit bidirectional voltage-level translator
    • onsemi NL17SZ00 single 2-input NAND gate
    • onsemi ESD7104MUTAG 4-ch. ESD protection diode array
    FixBot'a Sor
  12. Amazon Astro Chip ID: adım 12, 1 resimden 1.
    • Texas Instruments TMP103C temperature sensor
    • Texas Instruments TMP103D temperature sensor
    FixBot'a Sor
  13. Amazon Astro Chip ID, Sensor Board Side 2: adım 13, 2 resimden 1. Amazon Astro Chip ID, Sensor Board Side 2: adım 13, 2 resimden 2.
    • Chip ID, part 1:
    • Altek AL6100-32M2 3D depth sensing processor
    • Texas Instruments TUSB8042 4-port USB 3.1 hub controller
    • Texas Instruments TS3USB30E USB 2.0 SPDT analog switch
    • Monolithic Power Systems MP3428A 19 A synchronous boost converter
    FixBot'a Sor
  14. Amazon Astro Chip ID: adım 14, 1 resimden 1.
    • Chip ID, part 2:
    • Monolithic Power Systems MP5016HGQH current limit switch
    • Texas Instruments TCA9406 2-bit bidirectional voltage level translator
    • Diodes Incorporated 74LVC1G08 single 2-input AND gate
    FixBot'a Sor
  15. Amazon Astro Chip ID: adım 15, 1 resimden 1.
    • Chip ID, part 3 - sensors:
    • Texas Instruments TMP103F temperature sensor
    FixBot'a Sor
  16. Amazon Astro Chip ID, Motor Board Side 1: adım 16, 1 resimden 1.
    • Chip ID, part 1:
    • STMicroelectronics STM32L4P5VE 32-bit ARM Cortex-M4 microcontroller
    • SiTime MEMS Oscillator
    • Texas Instruments TPS3700 voltage detector
    • Renesas ISL9241H Li-ion buck boost battery charger
    • Texas Instruments DRV8323S 3-phase gate driver (for motor driving)
    • Texas Instruments TLA2024 12-bit analog-to-digital converter
    FixBot'a Sor
  17. Amazon Astro Chip ID: adım 17, 1 resimden 1.
    • Chip ID, part 2:
    • Texas Instruments TPS60400 60 mA charge pump voltage inverter
    • Texas Instruments LM5166 500 mA synchronous buck converter
    • Vishay SiP32430 load switch
    FixBot'a Sor
  18. Amazon Astro Chip ID: adım 18, 1 resimden 1.
    • Chip ID, part 3:
    • Nexperia 74AUP1G08 single 2-input AND gate
    • Nexperia 74AUP1G38 single 2-input NAND gate
    FixBot'a Sor
  19. Amazon Astro Chip ID: adım 19, 1 resimden 1.
    • Invensense ICM-20689 6-axis MEMS accelerometer & gyroscope
    • Texas Instruments TMP1075 temperature sensor
    • Texas Instruments TMP103x temperature sensor (likely)
    FixBot'a Sor
  20. Amazon Astro Chip ID, Motor Board Side 2: adım 20, 2 resimden 1. Amazon Astro Chip ID, Motor Board Side 2: adım 20, 2 resimden 2.
    • Chip ID, part 1:
    • STMicroelectronics STM32F765IG 32-bit ARM Cortex-M7 microcontroller
    • STMicroelectronics STM32F446VC 32-bit ARM Cortex-M4 microcontroller
    • STMicroelectronics L6234D three phase motor driver
    • Texas Instruments TPS24751 12 A eFuse w/ current monitor
    • Texas Instruments TLV7031 single comparator
    • Texas Instruments TLV7041 single comparator
    FixBot'a Sor
  21. Amazon Astro Chip ID: adım 21, 1 resimden 1.
    • Chip ID, part 2:
    • Texas Instruments INA231 16-bit current/voltage/power monitor
    • Nexperia 74HC4051 SP8T analog switch
    • Nexperia 74HC4053 triple SPDT analog switch
    • Nexperia 74AUP1G11 single 3-input AND gate
    • Nexperia 74LVC2G02 dual 2-input NOR gate
    FixBot'a Sor
  22. Amazon Astro Chip ID: adım 22, 1 resimden 1.
    • Chip ID, part 3:
    • Texas Instruments TXS0108E 8-bit bidirectional voltage-level shifter
    • Texas Instruments TCA9406 2-bit bidirectional voltage-level translator (possibly ?)
    FixBot'a Sor
  23. Amazon Astro Chip ID: adım 23, 1 resimden 1.
    FixBot'a Sor
1Rehber Yorum
Do you guys plan on doing the S23? It seems as though others already have units and are doing teardowns. I was hoping ifixit would be among the first as you are very thorough with your differences and inspections. I especially like the Xrays. Maybe it could offer some insight into the improved speaker design.
Damien Lobb - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 41
Her zaman: 2,241
