Ana içeriğe geç
Amazon Echo 2nd Generation AMP Board Replacement
Neye ihtiyacın var
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: adım 1, 3 resimden 1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: adım 1, 3 resimden 2. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: adım 1, 3 resimden 3.
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation AMP Board Replacement: adım 2, 3 resimden 1. Amazon Echo 2nd Generation AMP Board Replacement: adım 2, 3 resimden 2. Amazon Echo 2nd Generation AMP Board Replacement: adım 2, 3 resimden 3.
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation AMP Board Replacement: adım 3, 2 resimden 1. Amazon Echo 2nd Generation AMP Board Replacement: adım 3, 2 resimden 2.
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Inman
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S4G4
3 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Can anyone find a replacement board?
Tristan Parks - Yanıt
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - Yanıt
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 3,306
