Ana içeriğe geç
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
Neye ihtiyacın var
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 3.
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 2, 3 resimden 1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 2, 3 resimden 2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 2, 3 resimden 3.
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 3, 3 resimden 1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 3, 3 resimden 2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 3, 3 resimden 3.
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 4, 1 resimden 1.
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 5, 3 resimden 1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 5, 3 resimden 2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 5, 3 resimden 3.
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 6, 3 resimden 1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 6, 3 resimden 2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: adım 6, 3 resimden 3.
    • Remove the ribbon cable from the slot on the LED/speaker board
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Errica Snelling
652 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
5 Yorum
Where do you get the replacement cable from?
jonathan kabitzke - Yanıt
Yes, where can one get replacement ribbon cables?
Armando Morreale - Yanıt
Malcolm oakley - Yanıt
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Yanıt
no cable available, just waiting for donors
Ray Floyd Cabrera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 2,464
