Ana içeriğe geç
Amazon Echo Dot 3rd Gen Disassembly
Neye ihtiyacın var
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: adım 1, 3 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: adım 1, 3 resimden 2. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: adım 1, 3 resimden 3.
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: adım 2, 3 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: adım 2, 3 resimden 2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: adım 2, 3 resimden 3.
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: adım 3, 3 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: adım 3, 3 resimden 2. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: adım 3, 3 resimden 3.
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: adım 4, 3 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: adım 4, 3 resimden 2. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: adım 4, 3 resimden 3.
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: adım 5, 3 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: adım 5, 3 resimden 2. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: adım 5, 3 resimden 3.
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: adım 6, 2 resimden 1. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: adım 6, 2 resimden 2.
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ben Nicholsonb
322 İtibar
1 Kılavuz yazıldı
3Kılavuz Yorumları
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - Yanıt
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - Yanıt
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 113
Son 30 gün: 453
Her zaman: 15,713
