Ana içeriğe geç
Amazon Echo Dot 3rd Generation Casing Replacement
Neye ihtiyacın var
  1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: adım 1, 3 resimden 1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: adım 1, 3 resimden 2. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: adım 1, 3 resimden 3.
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Casing Replacement: adım 2, 2 resimden 1. Amazon Echo Dot 3rd Generation Casing Replacement: adım 2, 2 resimden 2.
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Casing Replacement: adım 3, 1 resimden 1.
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Casing Replacement: adım 4, 2 resimden 1. Amazon Echo Dot 3rd Generation Casing Replacement: adım 4, 2 resimden 2.
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
Sonuç
To reassemble your Echo Dot, follow these instructions in reverse order. Ensure the casing fits properly before tightening the screws back on. Once reassembly is finished, check that the device powers on and functions correctly.
2 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
100.214 İtibar
258 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.764 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 1,159
