Ana içeriğe geç
Amazon Echo Dot 5th Generation Motherboard Replacement
Neye ihtiyacın var
  1. Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Motherboard Replacement: adım 2, 1 resimden 1.
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Motherboard Replacement: adım 3, 3 resimden 1. Amazon Echo Dot 5th Generation Motherboard Replacement: adım 3, 3 resimden 2. Amazon Echo Dot 5th Generation Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
Sonuç
Grace Warila
206 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 üyesi
UMASSD-KONN-F23S3G4
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 40
Her zaman: 924
