Giriş
Amazon's Echo line is expanding—or in the Dot's case, shrinking! The new hockey-puck-sized Echo Dot lets you add some Alexa-infused personality to your existing home speaker setup. We're eager to try it, but not before we've thoroughly taken it apart. Alexa, brace yourself—it's teardown time.
If you're curious about the innards of the other Echos, we've got teardowns of the original Echo and the Amazon Tap as well.
Teardowning is what we do! Follow us on Instagram, Twitter, and Facebook for all the latest repair news.
Neye ihtiyacın var
If Amazon ever ventures into the canned tuna fish business, they'll have a great package design ready to go. In the meantime, the Dot contains some tasty morsels:
Dual-band, dual-antenna 802.11 a/g/b/n Wi-Fi with MIMO
Alexa Voice Search
7-microphone array
Light ring volume adjustment
Bluetooth 4.0 for sending and receiving audio
3.5 mm audio output for external speakers
Topside, the Dot looks exactly like its older brother, the Echo, complete with its action and mic mute buttons, light ring, volume ring, and microphone array.
Things are a little different down below, where we're greeted by a rubber cover and some labeling—and not much else.
Amazon bestows the Dot with a new model number: S04WQR.
For a more exacting visual comparison, we dug up an original Echo.
And by "dug up," we mean we grabbed it from the corner of the teardown table, where it has been faithfully serving up groovy repair tunes ever since we reassembled it.
TL;DR: it looks like Amazon pretty much just chopped out the middle of the old Echo. Neat!
We peel away the grippy rubber pad, fully expecting to find our first screws—but instead, we're greeted by glue. Boo!
We'd like to report that the lower case simply clips in place, but when the first opening pick fails to pop it free, we insert another. And another. And another.
Yep—it's glued, too.
We wrestle it free eventually, but so far the Dot is off to a decidedly less friendly start than its older sibling.
Our first look inside reveals what sophisticated tech insiders will instantly recognize as a big metal thing.
Fortunately, this metal thing has screws! Some long T6 Torx screws are threaded through the Dot from bottom to top; our driver dispatches them forthwith.
Out tumbles the metal thing, with a small speaker riding piggyback.
Yep, it's a speaker, albeit a small one. It connects to the Dot by way of a couple pairs of spring contacts.
The speaker is lightly adhered to this shapely blob of steel, which seems to be a simple weight in the base of the Dot. It's likely designed to keep the device planted, so you can twist the volume ring without accidentally spinning your Dot across the table.
With the screws removed, only a thin ribbon cable ties all these layers together. Introducing Amazon Echo Dot: Accordion Edition.
We shuffle the layers of plastic and silicon back together temporarily; it's all coming apart soon enough.
After tweezing away the ribbon cable, we're ready to inspect the motherboard.
Chips on one side, ports on the other. Here's what this motherboard is packing:
Texas Instruments DM3725CUS100 Digital Media Processor
Micron MT46H64M32LFBQ 256 MB (16 Meg x 32 x 4 Banks) LPDDR SDRAM
Samsung KLM4G1FEPD-B031 4 GB High Performance eMMC NAND Flash Memory
Qualcomm Atheros QCA6234 Integrated Dual-Band 2x2 802.11n + Bluetooth 4.0 SiP
Texas Instruments TPS65910A1 Integrated Power Management IC
Texas Instruments TLV320DAC3203 Low Power Stereo Audio Codec w/ Headphone Amplifier
Texas Instruments TPA2025D1 2 W Class D Speaker Amplifier
IC identification, continued:
Monolithic Power Systems MP2145GD 6 A synchronous step-down converter
Maxim Integrated MAX14585AEVB+ hi-speed USB analog switch
NXP Semiconductor NX3L1G3157 SPDT analog switch
Texas Instruments LP3985IM5X-3.0 150 mA / 3.0 V LDO regulator
Diodes Incorporated 74LVC1G125 single buffer
With disassembly nearly complete, we tear into the control wheel. It's a dead ringer for the one we found in the original Echo, complete with its geared encoder wheel.
That's just fine by us, since it means at least some replacements parts can likely be shared between the original Echo and the Dot.
It also means servicing instructions for one will likely be echoed by the other. All in all, it's a win for fans of repair and bad puns everywhere.
And buried in the top layer we find another control board, functionally identical to the one we dug up in the original Echo.
National Semiconductor LP55231 Programmable 9-Output LED Driver (x4)
Texas Instruments TLV320ADC3101 92dB SNR Low-Power Stereo ADC (x4)
Diodes Incorporated LMV321SE Single Operational Amplifier
Texas Instruments SN74LVC74A Dual Positive-Edge-Triggered D-Type Flip-Flops
Diodes Incorporated 74LVC1G14 Schmitt Trigger Inverter
Diodes Incorporated 74LVC1G125 Single Buffer (x2)
Amazon Echo Dot Repairability Score: 6 out of 10 (10 is the easiest to repair)
The majority of the device is held together by standard Torx screws.
Many components are common to the original Echo, making it easier to source parts.
The rubber foot, base cap, and speakers are held in place with tough adhesive.
The headphone jack and USB port, two common points of failure, are soldered directly to the motherboard.
51Kılavuz Yorumları
Still can't figure out the microphone manufacturer?
Microphones are Knowles :: SiSonic™ Microphones http://www.knowles.com/eng/Products/SiSo...
Can we know which model exactly ? or at-least its near specifications ?
Most likely SPA1687LR5H-1 since it is connected to the ADCs differential inputs and meets the specs and the dimensions.
Johannes
does this have the same audio amp as the Echo (TI TPA3110D2)
