Giriş
This guide demonstrates how to remove the LED/Microphone board. This board contains the LED indication ring at the top of the Echo, as well as the seven microphone array. This guide should assist you if the LED ring is malfunctioning or if the Echo has issues hearing you.
Neye ihtiyacın var
Peel off the rubber footing from the bottom of the Echo.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where can i buy this LED/Microphone board for replacement?
