Giriş
The Amazon Echo Look's primary function as a fashion assistant can be affected if the Wi-Fi module is damaged. The device uses Wi-Fi in order to use its main features such as looking for wardrobes; a damaged Wi-Fi module can hinder that.
Neye ihtiyacın var
Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
Remove the screws from the midframe with a Torx T5 screwdriver.
Lift up the midframe
Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
Bir başkası bu kılavuzu tamamladı.
